HP 250 G3, Shutdown/Restart solution
Hello everyone,
I am running Ubuntu Mate 15.04 on my machine. I have had issues for the past year running different Ubuntu derivates. The issue was that every time I wanted to shutdown or restart, my system decided to halt. So, what I did was search for a solution (rather unsuccessfully.) For all who suffer from the same problem. Here is how to get rid of the issue:
  1. Go to the BIOS settings (press Esc during boot)
  2. Change the USB3 setting (you will find it in pre-OS option) from “automatic” to “enabled”
That’s it. From now on restart, shutdown, and suspend should work as it should.
Thanks for sharing! Haven’t encountered the issue myself (yet), but I’ll make sure to remember :slight_smile:
¡Muchísimas gracias!
Thank you very much!
I’ve had the same problem in my new computer. :slight_smile:
Thanks so much! I had the same issue with a brand new install on my HP 250 G3. Freezing on suspend was my big issue, and it would freeze instantly when I closed the lid. Tried several distros and kernels. This is the first I’ve seen about USB3.0 being a factor.
Yes, great!
I made some attempts (from Debian 9 KDE) with kernel parameters and I had some small success with “quiet splash intel_idle.max_cstate=1”, however this just helped with shutdown. After suspend the kbd/mouse has still freezed in 80% of cases.
With bios/usb3=enable this really works well, no need to change kernel parameters at all.
