Hi, I switched from Linux Mint 17.3 to ubuntu mate 16.04
With mint 17.3 no problem with my printer Samsung CLX-3305
With Mate 16.04 printer become quickly inactive and in cups error_log i get many messages : E [10/Jul/2016:15:41:54 +0200] [cups-deviced] PID 8989 (gutenprint52+usb) stopped with status 1!
It looks very similar with problem described above .
CLX-3305 is also a scanner and it is difficult to work with in 16.04
I hope somebody is working on this problem so I am not obliged to switch back to Mint
Regards
Still having a bear of a time getting this thing to work, so I did a hardware workaround by installing cups on a raspberry pi. Splix drivers from debian arm are working fine, so donât know what the hangup is.
Hi Wolfman, thanks to try help me.
I uninstall libgutenprint2 5.2.11.1 and install 5.2.10~pre2-0ubuntu2.
I got same problem , I can just after reboot print a document , after printer become inactive in properties and i cannot print anymore
I verified on another PC still mint 17.3 and it is well 5.2.10~pre2-0ubuntu2 ....
One thing more.
I am not sure that is a printing problem. In fact my CLX-3305 is also a scanner and when printer become inactive scanner doesnât work anymore .
May be is a USB device management problem âŠ
Hi @yannick,
try running the following terminal commands (Ctrl + Alt + t) and see if you have any missing dependencies?:
Hi Wolfman, I ran the 2 commands and there is not any problem.
But I try again uninstall libgutenprint2 5.2.11.1 and install 5.2.10~pre2-0ubuntu2.
With uninstall 5.2.11.1 printer-driver-gutenprint is also uninstalled , So I deleted my printer and wait to system detect it again, it never detect it , i cannot add a new printer
How intall printer-driver-gutenprint from trusty ?
Hi Wolfman,
It doesnât work, is it possible to downgrade cups ?
Difficult for me to have no printer a long time so I will go back to Linux mint in a few days
Many thanks for your help
Yannick
Hi @yannick,
download either the 32 or 64 bit versions from here and try them?:
https://pkgs.org/ubuntu-14.04/ubuntu-main-amd64/cups_1.7.2-0ubuntu1_amd64.deb.html
https://pkgs.org/ubuntu-14.04/ubuntu-main-i386/cups_1.7.2-0ubuntu1_i386.deb.html
Hi Wolfman
I think the problem with 16.04 is about disconnect usb samsung device
In /var/log/syslog i see disconnect reconnect and device id changed
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.156927] usb 3-11: USB disconnect, device number 12
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.157087] usblp2: removed
Jul 18 10:28:13 jarno-MS-7817 udev-configure-printer[2987]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-11
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.428795] usb 3-11: new high-speed USB device number 13 using xhci_hcd
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557549] usb 3-11: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557552] usb 3-11: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557553] usb 3-11: Product: CLX-3300 Series
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557554] usb 3-11: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557555] usb 3-11: SerialNumber: Z76KB8GF7E00AKV
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557635] usb 3-11: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557638] usb 3-11: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557640] usb 3-11: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.557643] usb 3-11: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.558053] usb 3-11: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.558055] usb 3-11: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:13 jarno-MS-7817 kernel: [ 590.558561] usblp 3-11:1.1: usblp2: USB Bidirectional printer dev 13 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 10:28:14 jarno-MS-7817 colord[858]: (colord:858): Cd-WARNING **: CdMain: failed to emit DeviceAdded: failed to register object: Un objet est déjà exporté pour l'interface « org.freedesktop.ColorManager.Device » en « /org/freedesktop/ColorManager/devices/sysfs_Samsung_Electronics_Co___Ltd__CLX_3300_Series »
Jul 18 10:28:14 jarno-MS-7817 systemd-udevd[2992]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 10:28:14 jarno-MS-7817 systemd-udevd[3008]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 10:28:14 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d11)...
Jul 18 10:28:14 jarno-MS-7817 udev-configure-printer[3007]: add /devices/pci0000:00/0000:00:14.0/usb3/3-11
Jul 18 10:28:14 jarno-MS-7817 udev-configure-printer[3007]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-11
Jul 18 10:28:14 jarno-MS-7817 udev-configure-printer[3007]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.320950] usb 3-11: USB disconnect, device number 13
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.321190] usblp2: removed
Jul 18 10:28:18 jarno-MS-7817 udev-configure-printer[3028]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-11
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.688869] usb 3-11: new high-speed USB device number 14 using xhci_hcd
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817587] usb 3-11: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817589] usb 3-11: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817590] usb 3-11: Product: CLX-3300 Series
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817591] usb 3-11: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817592] usb 3-11: SerialNumber: Z76KB8GF7E00AKV
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817671] usb 3-11: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817674] usb 3-11: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817676] usb 3-11: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.817678] usb 3-11: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.818114] usb 3-11: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.818117] usb 3-11: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:18 jarno-MS-7817 kernel: [ 595.818787] usblp 3-11:1.1: usblp2: USB Bidirectional printer dev 14 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 10:28:19 jarno-MS-7817 kernel: [ 596.122740] usblp2: removed
Jul 18 10:28:19 jarno-MS-7817 kernel: [ 596.123385] usb 3-11: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:19 jarno-MS-7817 kernel: [ 596.123389] usb 3-11: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 10:28:19 jarno-MS-7817 kernel: [ 596.123977] usblp 3-11:1.1: usblp2: USB Bidirectional printer dev 14 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 10:28:19 jarno-MS-7817 colord[858]: (colord:858): Cd-WARNING **: CdMain: failed to emit DeviceAdded: failed to register object: Un objet est déjà exporté pour l'interface « org.freedesktop.ColorManager.Device » en « /org/freedesktop/ColorManager/devices/sysfs_Samsung_Electronics_Co___Ltd__CLX_3300_Series »
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3007]: URI contains USB serial number
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3007]: URI match: usb://Samsung/CLX-3300%20Series?serial=Z76KB8GF7E00AKV&interface=1
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3028]: URI of detected printer: usb://Samsung/CLX-3300%20Series?serial=Z76KB8GF7E00AKV&interface=1, normalized: samsung clx 3300 series serial z76kb8gf7e00akv interface 1
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3028]: URI of print queue: usb://Samsung/CLX-3300%20Series?serial=Z76KB8GF7E00AKV&interface=1, normalized: samsung clx 3300 series serial z76kb8gf7e00akv interface 1
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3028]: Queue ipp://localhost/printers/CLX-3300-Series has matching device URI
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3007]: URI of detected printer: usb://Samsung/CLX-3300%20Series?serial=Z76KB8GF7E00AKV&interface=1, normalized: samsung clx 3300 series serial z76kb8gf7e00akv interface 1
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3007]: URI of print queue: usb://Samsung/CLX-3300%20Series?serial=Z76KB8GF7E00AKV&interface=1, normalized: samsung clx 3300 series serial z76kb8gf7e00akv interface 1
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3007]: Queue ipp://localhost/printers/CLX-3300-Series has matching device URI
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3007]: URI of print queue: cups-pdf:/, normalized: cups pdf
Jul 18 10:28:20 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d11).
Jul 18 10:28:20 jarno-MS-7817 udev-configure-printer[3028]: Disabled printer ipp://localhost/printers/CLX-3300-Series as the corresponding device was unplugged or turned off
With lsusb device id changed one minute later
Bus 003 Device 019: ID 04e8:3456 Samsung Electronics Co., Ltd
Bus 003 Device 021: ID 04e8:3456 Samsung Electronics Co., Ltd
I never had this type of problem before
Regards
Hi @yannick,
it is a little difficult for me to replicate your problem as I donât have a Samsung printer!. That said, try removing the printer in Control Center > Administration > Printers and restart with the printer switched off and once restarted, switch it back on and see what happens?.
See also:
Please find below the syslog after printer switched on
part 1
15:45:20 jarno-MS-7817 kernel: [ 40.033946] usb 3-9: new high-speed USB device number 8 using xhci_hcd
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162772] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162774] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162775] usb 3-9: Product: CLX-3300 Series
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162776] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162777] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162857] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162859] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162861] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.162863] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.163224] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.163227] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:20 jarno-MS-7817 kernel: [ 40.163688] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 8 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:45:20 jarno-MS-7817 systemd-udevd[2160]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:20 jarno-MS-7817 systemd-udevd[2174]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:20 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:45:20 jarno-MS-7817 udev-configure-printer[2177]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:20 jarno-MS-7817 udev-configure-printer[2177]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:20 jarno-MS-7817 udev-configure-printer[2177]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:45:25 jarno-MS-7817 colord[888]: (colord:888): Cd-WARNING **: failed to get session [pid 2178]: Aucun périphérique ou adresse
Jul 18 15:45:25 jarno-MS-7817 colord[888]: (colord:888): Cd-WARNING **: CdMain: failed to read /proc/2178/cmdline
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 45.869721] usb 3-9: USB disconnect, device number 8
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 45.869915] usblp2: removed
Jul 18 15:45:26 jarno-MS-7817 udev-configure-printer[2226]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.205652] usb 3-9: new high-speed USB device number 9 using xhci_hcd
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334438] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334440] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334442] usb 3-9: Product: CLX-3300 Series
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334443] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334443] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334518] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334521] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334523] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.334525] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.335141] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.335144] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:26 jarno-MS-7817 kernel: [ 46.335640] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 9 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:45:26 jarno-MS-7817 udev-configure-printer[2177]: no corresponding CUPS device found
Jul 18 15:45:26 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:45:26 jarno-MS-7817 systemd-udevd[2223]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:26 jarno-MS-7817 systemd-udevd[2224]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:27 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:45:27 jarno-MS-7817 udev-configure-printer[2252]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:27 jarno-MS-7817 udev-configure-printer[2252]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:27 jarno-MS-7817 udev-configure-printer[2252]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.033438] usb 3-9: USB disconnect, device number 9
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.036362] usblp2: removed
Jul 18 15:45:32 jarno-MS-7817 udev-configure-printer[2291]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.373353] usb 3-9: new high-speed USB device number 10 using xhci_hcd
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502117] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502119] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502120] usb 3-9: Product: CLX-3300 Series
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502121] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502122] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502250] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502253] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502255] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502258] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502621] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.502623] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:32 jarno-MS-7817 kernel: [ 52.503240] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 10 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:45:33 jarno-MS-7817 udev-configure-printer[2252]: no corresponding CUPS device found
Jul 18 15:45:33 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:45:33 jarno-MS-7817 systemd-udevd[2292]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:33 jarno-MS-7817 systemd-udevd[2290]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:33 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:45:33 jarno-MS-7817 udev-configure-printer[2311]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:33 jarno-MS-7817 udev-configure-printer[2311]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:33 jarno-MS-7817 udev-configure-printer[2311]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:45:36 jarno-MS-7817 systemd[1]: Starting Stop ureadahead data collection...
Jul 18 15:45:36 jarno-MS-7817 systemd[1]: Stopped Read required files in advance.
Jul 18 15:45:36 jarno-MS-7817 systemd[1]: Started Stop ureadahead data collection.
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.257126] usb 3-9: USB disconnect, device number 10
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.257326] usblp2: removed
Jul 18 15:45:38 jarno-MS-7817 udev-configure-printer[2353]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.561057] usb 3-9: new high-speed USB device number 11 using xhci_hcd
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.689930] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.689932] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.689933] usb 3-9: Product: CLX-3300 Series
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.689934] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.689935] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.690011] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.690014] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.690016] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.690018] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.690398] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.690400] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:38 jarno-MS-7817 kernel: [ 58.690844] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 11 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:45:39 jarno-MS-7817 udev-configure-printer[2311]: no corresponding CUPS device found
Jul 18 15:45:39 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:45:39 jarno-MS-7817 systemd-udevd[2351]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:39 jarno-MS-7817 systemd-udevd[2350]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:39 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:45:39 jarno-MS-7817 udev-configure-printer[2380]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:39 jarno-MS-7817 udev-configure-printer[2380]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:39 jarno-MS-7817 udev-configure-printer[2380]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:45:44 jarno-MS-7817 kernel: [ 64.396805] usb 3-9: USB disconnect, device number 11
Jul 18 15:45:44 jarno-MS-7817 kernel: [ 64.396922] usblp2: removed
Jul 18 15:45:44 jarno-MS-7817 udev-configure-printer[2411]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:44 jarno-MS-7817 kernel: [ 64.732762] usb 3-9: new high-speed USB device number 12 using xhci_hcd
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861543] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861544] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861546] usb 3-9: Product: CLX-3300 Series
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861547] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861547] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861621] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861624] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861626] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861628] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861988] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.861990] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:45 jarno-MS-7817 kernel: [ 64.862471] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 12 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:45:45 jarno-MS-7817 udev-configure-printer[2380]: no corresponding CUPS device found
Jul 18 15:45:45 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:45:45 jarno-MS-7817 systemd-udevd[2408]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:45 jarno-MS-7817 systemd-udevd[2409]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:45 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:45:45 jarno-MS-7817 udev-configure-printer[2438]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:45 jarno-MS-7817 udev-configure-printer[2438]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:45 jarno-MS-7817 udev-configure-printer[2438]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:45:47 jarno-MS-7817 blueman-mechanism: Exiting
Jul 18 15:45:50 jarno-MS-7817 kernel: [ 70.592513] usb 3-9: USB disconnect, device number 12
Jul 18 15:45:50 jarno-MS-7817 kernel: [ 70.592639] usblp2: removed
Jul 18 15:45:50 jarno-MS-7817 udev-configure-printer[2467]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
part 2
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 70.928481] usb 3-9: new high-speed USB device number 13 using xhci_hcd
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057329] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057331] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057332] usb 3-9: Product: CLX-3300 Series
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057333] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057334] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057410] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057414] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057415] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057417] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057797] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.057799] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:51 jarno-MS-7817 kernel: [ 71.058245] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 13 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:45:51 jarno-MS-7817 udev-configure-printer[2438]: no corresponding CUPS device found
Jul 18 15:45:51 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:45:51 jarno-MS-7817 systemd-udevd[2465]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:51 jarno-MS-7817 systemd-udevd[2464]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:51 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:45:51 jarno-MS-7817 udev-configure-printer[2488]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:51 jarno-MS-7817 udev-configure-printer[2488]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:51 jarno-MS-7817 udev-configure-printer[2488]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:45:56 jarno-MS-7817 kernel: [ 76.844220] usb 3-9: USB disconnect, device number 13
Jul 18 15:45:56 jarno-MS-7817 kernel: [ 76.844351] usblp2: removed
Jul 18 15:45:57 jarno-MS-7817 udev-configure-printer[2521]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.148166] usb 3-9: new high-speed USB device number 14 using xhci_hcd
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277010] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277012] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277013] usb 3-9: Product: CLX-3300 Series
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277014] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277015] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277092] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277095] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277097] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277099] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277477] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277479] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:45:57 jarno-MS-7817 kernel: [ 77.277935] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 14 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:45:57 jarno-MS-7817 udev-configure-printer[2488]: no corresponding CUPS device found
Jul 18 15:45:57 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:45:57 jarno-MS-7817 systemd-udevd[2519]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:57 jarno-MS-7817 systemd-udevd[2518]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:45:57 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:45:57 jarno-MS-7817 udev-configure-printer[2543]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:57 jarno-MS-7817 udev-configure-printer[2543]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:45:57 jarno-MS-7817 udev-configure-printer[2543]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.007960] usb 3-9: USB disconnect, device number 14
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.008138] usblp2: removed
Jul 18 15:46:03 jarno-MS-7817 udev-configure-printer[2587]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.347847] usb 3-9: new high-speed USB device number 15 using xhci_hcd
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476516] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476518] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476519] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476520] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476521] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476619] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476622] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476624] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.476626] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.477280] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.477283] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:03 jarno-MS-7817 kernel: [ 83.477727] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 15 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:03 jarno-MS-7817 udev-configure-printer[2543]: no corresponding CUPS device found
Jul 18 15:46:03 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:04 jarno-MS-7817 systemd-udevd[2584]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:04 jarno-MS-7817 systemd-udevd[2585]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:04 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:04 jarno-MS-7817 udev-configure-printer[2611]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:04 jarno-MS-7817 udev-configure-printer[2611]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:04 jarno-MS-7817 udev-configure-printer[2611]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.247639] usb 3-9: USB disconnect, device number 15
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.247858] usblp2: removed
Jul 18 15:46:09 jarno-MS-7817 udev-configure-printer[2644]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.551571] usb 3-9: new high-speed USB device number 16 using xhci_hcd
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680376] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680379] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680380] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680382] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680383] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680479] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680483] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680486] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680488] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680848] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.680851] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:09 jarno-MS-7817 kernel: [ 89.681334] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 16 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:10 jarno-MS-7817 udev-configure-printer[2611]: no corresponding CUPS device found
Jul 18 15:46:10 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:10 jarno-MS-7817 systemd-udevd[2648]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:10 jarno-MS-7817 systemd-udevd[2643]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:10 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:10 jarno-MS-7817 udev-configure-printer[2668]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:10 jarno-MS-7817 udev-configure-printer[2668]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:10 jarno-MS-7817 udev-configure-printer[2668]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:15 jarno-MS-7817 kernel: [ 95.447319] usb 3-9: USB disconnect, device number 16
Jul 18 15:46:15 jarno-MS-7817 kernel: [ 95.447441] usblp2: removed
Jul 18 15:46:15 jarno-MS-7817 udev-configure-printer[2700]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:15 jarno-MS-7817 kernel: [ 95.751275] usb 3-9: new high-speed USB device number 17 using xhci_hcd
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880042] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880045] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880047] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880048] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880049] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880215] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880221] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880224] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880226] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880618] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.880622] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:16 jarno-MS-7817 kernel: [ 95.881137] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 17 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:16 jarno-MS-7817 udev-configure-printer[2668]: no corresponding CUPS device found
Jul 18 15:46:16 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:16 jarno-MS-7817 systemd-udevd[2698]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:16 jarno-MS-7817 systemd-udevd[2697]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:16 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:16 jarno-MS-7817 udev-configure-printer[2724]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:16 jarno-MS-7817 udev-configure-printer[2724]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:16 jarno-MS-7817 udev-configure-printer[2724]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:21 jarno-MS-7817 kernel: [ 101.595028] usb 3-9: USB disconnect, device number 17
Jul 18 15:46:21 jarno-MS-7817 kernel: [ 101.595144] usblp2: removed
Jul 18 15:46:21 jarno-MS-7817 udev-configure-printer[2753]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 101.930977] usb 3-9: new high-speed USB device number 18 using xhci_hcd
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059784] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059786] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059787] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059788] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059789] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059869] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059872] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059874] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.059876] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.060232] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.060234] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:22 jarno-MS-7817 kernel: [ 102.060700] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 18 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:22 jarno-MS-7817 udev-configure-printer[2724]: no corresponding CUPS device found
Jul 18 15:46:22 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:22 jarno-MS-7817 systemd-udevd[2750]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:22 jarno-MS-7817 systemd-udevd[2751]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:22 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:22 jarno-MS-7817 udev-configure-printer[2776]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:22 jarno-MS-7817 udev-configure-printer[2776]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:22 jarno-MS-7817 udev-configure-printer[2776]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:27 jarno-MS-7817 kernel: [ 107.822721] usb 3-9: USB disconnect, device number 18
Jul 18 15:46:27 jarno-MS-7817 kernel: [ 107.822840] usblp2: removed
Jul 18 15:46:27 jarno-MS-7817 udev-configure-printer[2817]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.126680] usb 3-9: new high-speed USB device number 19 using xhci_hcd
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255376] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255378] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255380] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255381] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255382] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255459] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255462] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255464] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255466] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255846] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.255848] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:28 jarno-MS-7817 kernel: [ 108.256296] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 19 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:28 jarno-MS-7817 udev-configure-printer[2776]: no corresponding CUPS device found
Jul 18 15:46:28 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:28 jarno-MS-7817 systemd-udevd[2814]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:28 jarno-MS-7817 systemd-udevd[2815]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:28 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:28 jarno-MS-7817 udev-configure-printer[2840]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:28 jarno-MS-7817 udev-configure-printer[2840]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:28 jarno-MS-7817 udev-configure-printer[2840]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.014466] usb 3-9: USB disconnect, device number 19
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.014595] usblp2: removed
Jul 18 15:46:34 jarno-MS-7817 udev-configure-printer[2872]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.318396] usb 3-9: new high-speed USB device number 20 using xhci_hcd
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447174] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447177] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447179] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447180] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447181] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447277] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447281] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447283] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.447286] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.448214] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.448219] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:34 jarno-MS-7817 kernel: [ 114.448855] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 20 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:34 jarno-MS-7817 udev-configure-printer[2840]: no corresponding CUPS device found
Jul 18 15:46:34 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:35 jarno-MS-7817 systemd-udevd[2869]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:35 jarno-MS-7817 systemd-udevd[2870]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:35 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:35 jarno-MS-7817 udev-configure-printer[2892]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:35 jarno-MS-7817 udev-configure-printer[2892]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:35 jarno-MS-7817 udev-configure-printer[2892]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.214129] usb 3-9: USB disconnect, device number 20
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.214260] usblp2: removed
Jul 18 15:46:40 jarno-MS-7817 udev-configure-printer[2925]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.518086] usb 3-9: new high-speed USB device number 21 using xhci_hcd
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646828] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646829] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646831] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646832] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646833] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646908] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646911] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646913] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.646915] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.647559] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.647561] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:40 jarno-MS-7817 kernel: [ 120.648006] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 21 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:41 jarno-MS-7817 udev-configure-printer[2892]: no corresponding CUPS device found
Jul 18 15:46:41 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:41 jarno-MS-7817 systemd-udevd[2923]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:41 jarno-MS-7817 systemd-udevd[2922]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:41 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:41 jarno-MS-7817 udev-configure-printer[2947]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:41 jarno-MS-7817 udev-configure-printer[2947]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:41 jarno-MS-7817 udev-configure-printer[2947]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.377910] usb 3-9: USB disconnect, device number 21
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.378078] usblp2: removed
Jul 18 15:46:46 jarno-MS-7817 udev-configure-printer[2980]: remove /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.713801] usb 3-9: new high-speed USB device number 22 using xhci_hcd
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842475] usb 3-9: New USB device found, idVendor=04e8, idProduct=3456
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842478] usb 3-9: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842480] usb 3-9: Product: CLX-3300 Series
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842481] usb 3-9: Manufacturer: Samsung Electronics Co., Ltd.
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842482] usb 3-9: SerialNumber: Z76KB8GF7E00AKV
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842583] usb 3-9: ep 0x4 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842587] usb 3-9: ep 0x83 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842590] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842592] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842985] usb 3-9: ep 0x2 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.842988] usb 3-9: ep 0x81 - rounding interval to 8 microframes, ep desc says 10 microframes
Jul 18 15:46:46 jarno-MS-7817 kernel: [ 126.843462] usblp 3-9:1.1: usblp2: USB Bidirectional printer dev 22 if 1 alt 0 proto 2 vid 0x04E8 pid 0x3456
Jul 18 15:46:47 jarno-MS-7817 udev-configure-printer[2947]: no corresponding CUPS device found
Jul 18 15:46:47 jarno-MS-7817 systemd[1]: Started Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9).
Jul 18 15:46:47 jarno-MS-7817 systemd-udevd[2979]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:47 jarno-MS-7817 systemd-udevd[2984]: Process '/bin/setfacl -m g:scanner:rw ' failed with exit code 2.
Jul 18 15:46:47 jarno-MS-7817 systemd[1]: Starting Automatic USB/Bluetooth printer setup (-devices-pci0000:00-0000:00:14.0-usb3-3\x2d9)...
Jul 18 15:46:47 jarno-MS-7817 udev-configure-printer[3003]: add /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:47 jarno-MS-7817 udev-configure-printer[3003]: device devpath is /devices/pci0000:00/0000:00:14.0/usb3/3-9
Jul 18 15:46:47 jarno-MS-7817 udev-configure-printer[3003]: MFG:Samsung MDL:CLX-3300 Series SERN:- serial:Z76KB8GF7E00AKV
From what I can see, âCupsâ is the culprit but I donât really know so try the following, change your software sources download location then run the following terminal command (Ctrl + Alt + t) and see what happens:
sudo apt-get update && sudo apt-get remove cups && sudo apt-get install cups
then restart and check your printer!.
Hi
Same problem with other source .
I understand "no corresponding CUPS device found" because device number has changed .
Each time I have a document in printer queue , I restart ubuntu and at the end of reboot, document is well printed.
If I try a second document , it is not printed because printer is inactive in printer properties.
I think it is inactive because device number has change ( i can verify with lsusb) .
Regards
In your picture; âActiveeâ is not ticked?, I assume that means âActiveâ or to âActivateâ the printer?.
Yes in printer properties TAB behavior the first line is âacivatedâ
If I check activated , queue a print and reboot, at the end of reboot printer properties is âactivatedâ , device id is 009 ( as discovered) and document is printed, about 30 seconds later device is disconnected and reconnected with a new device id but printer properties shows activated unchecked ( inactivated , I think normal because device 009 does not exist any more )
I donât understand why device number change very often. The scanner on same machine continue to work without any problem ( usb works )
Hmmmmmm?,
try changing the USB port?, shut down your PC and swap the printer cable to a different USB port and restart and see if that clears the problem?.
Hi, i have already swapped usb ports, change usb cable without success, and problem has occured only when i installed 16.04. Before with mint 17.3 (based on ubuntu 14.04) i never had any problem neither with printer or scanner. Best regards Yannick
