I cannot get my fresh install of 16.0.4 (64 bit) to output sound from any source. A reinstall of alsa-base and pulseaudio with the following did not work.
sudo apt-get remove --purge alsa-base pulseaudio
sudo apt-get install alsa-base pulseaudio
I’ve tried a couple of other options, including the removal of alsa-base.conf followed by a reboot and restore of the file.
It looks like ALSA simply does not support my sound card using the current configuration. Details from /proc/asound/oss/sndstat
Sound Driver:3.8.1a-980706 (ALSA emulation code)
Kernel: Linux xxxAspire-5742 4.4.0-21-generic #37-Ubuntu SMP Mon Apr 18 18:33:37 UTC 2016 x86_64
Config options: 0
Installed drivers:
Type 10: ALSA emulation
Card config:
HDA Intel MID at 0xb4400000 irq 27
Audio devices: NOT ENABLED IN CONFIG
Synth devices: NOT ENABLED IN CONFIG
Midi devices: NOT ENABLED IN CONFIG
Timers:
31: system timer
Mixers: NOT ENABLED IN CONFIG
Is there an alternative to ALSA and PULSE? Or, is there a way to manually force ALSA and/or PULSE to recognise the sound card?
