I installed the NVidia 390.48 driver but now the system does not start anymore. Black screen e cursor blinking… How to solve? Is the driver in question incompatible with mate?
Hello!
nvidia-installer log file '/var/log/nvidia-installer.log'
creation time: Sat May 5 18:50:36 2018
installer version: 390.48
PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/snap/bin
nvidia-installer command line:
./nvidia-installer
Unable to load: nvidia-installer ncurses v6 user interface
Using: nvidia-installer ncurses user interface
-> Detected 4 CPUs online; setting concurrency level to 4.
-> Installing NVIDIA driver version 390.48.
-> Running distribution scripts
executing: ‘/usr/lib/nvidia/pre-install’…
-> done.
-> The distribution-provided pre-install script failed! Are you sure you want to continue? (Answer: Continue installation)
-> Would you like to register the kernel module sources with DKMS? This will allow DKMS to automatically build a new module, if you install a different kernel later. (Answer: Yes)
-> Installing both new and classic TLS OpenGL libraries.
-> Installing both new and classic TLS 32bit OpenGL libraries.
-> Install NVIDIA’s 32-bit compatibility libraries? (Answer: Yes)
-> Will install GLVND GLX client libraries.
-> Will install GLVND EGL client libraries.
-> Skipping GLX non-GLVND file: “libGL.so.390.48”
-> Skipping GLX non-GLVND file: “libGL.so.1”
-> Skipping GLX non-GLVND file: “libGL.so”
-> Skipping EGL non-GLVND file: “libEGL.so.390.48”
-> Skipping EGL non-GLVND file: “libEGL.so”
-> Skipping EGL non-GLVND file: “libEGL.so.1”
-> Skipping GLX non-GLVND file: “./32/libGL.so.390.48”
-> Skipping EGL non-GLVND file: “./32/libEGL.so.390.48”
Looking for install checker script at ./libglvnd_install_checker/check-libglvnd-install.sh
executing: ‘/bin/sh ./libglvnd_install_checker/check-libglvnd-install.sh’…
Checking for libglvnd installation.
Checking libGLdispatch…
Checking libGLdispatch dispatch table
Checking call through libGLdispatch
All OK
libGLdispatch is OK
Checking for libGLX
libGLX is OK
Checking for libEGL
Got EGL_VENDOR string “NVIDIA”, expected “DUMMY VENDOR”
-> An incomplete installation of libglvnd was found. Do you want to install a full copy of libglvnd? This will overwrite any existing libglvnd libraries. (Answer: Install and overwrite existing files)
Will install libglvnd libraries.
Will install libEGL vendor library config file to /usr/share/glvnd/egl_vendor.d
-> Searching for conflicting files:
-> done.
-> Installing ‘NVIDIA Accelerated Graphics Driver for Linux-x86_64’ (390.48):
executing: ‘/sbin/ldconfig’…
-> done.
-> Driver file installation is complete.
-> Installing DKMS kernel module:
-> done.
-> Running post-install sanity check:
-> done.
-> Post-install sanity check passed.
-> Running runtime sanity check:
-> done.
-> Runtime sanity check passed.
-> Installation of the kernel module for the NVIDIA Accelerated Graphics Driver for Linux-x86_64 (version 390.48) is now complete.
