Enjoying 16.10, will there be an upgrade to next version from it?
You can upgrade now or wait for the final release of 17o4.
The Software Updater will offer a prompt just after when 17.04 is released, or as @anon42388993 says, you could upgrade now to the development versions, which I wouldn’t recommend if you desire a stable system.
sudo update-manager -d
Great, thanks all, just wanted to be sure, I shall stick with 16.10 for time being…
