A dock showed up on bottom panel
Hello All
Using UM 22.04
Don’t know how this happened, but a dock showed up on my bottom panel. I tried using: sudo apt purge plank libplank-common libplank1 -y. Dock is still there on panel.
Went to Mate tweak and dock grayed out. See attachment.
What can be done to remove the dock?
Layman's terms please.
Thanks mt
Dock still there
Dock grayed out
Did you recently change panels within Mate Tweak? Did you try right clicking the panel? You may be provide an option to delete.
Hello jaybo, I'm not sure what I did. I tried to put the arrow anywhere in the dock. The space between icons must be 1 pixel. I can't get any menu to show.
Any other ideas?
Thanks
mt
Have you tried changing panels using Mate Tweak? Try the traditional panel. Mate Tweak/Panel/Traditional
Hi expanding on above suggestion maybe
From here:
https://www.linuxuprising.com/2019/12/a-guide-to-using-plank-dock-on-linux.html
edit deleted mistaken copy paste which placed whole page in this post
On my UM22.04.2 system
d
jaybo...You da man.
Thank You so much!
mt
