Access partitions as root
If I open a file-manager (Caja, Thunar, PCManFM) as root in UM 16.04 I don’t get access to my other drives/partitions.
If I do the same (gksu) in UM 14.04 all my drives/partitions are available.
I don’t understand. Help…:weary:
I think that you must mount the other partitions first. Any partition not auto-mounted by your fstab file must be mounted before opening your file manager as root.
HTH.
Yes, you are 100 % correct. I don’t remember that it used to be like this. Anyway, problem solved. Thank you. :+1:
