Active x in ubuntu mate for raspberry pi 2
1 how to install wine in Ubuntu mate 15.10, are there any suggestions?
2 how to install .exe into raspberry Pi 2 if OS is Ubuntu mate 15.10?
Wine should be in the repo’s?, try this terminal command but I’m not sure if it works with Raspi?:
sudo apt-get install wine winbind winetricks
If you want to install a .exe file, right click and “open with wine
What apps are supported?:
https://appdb.winehq.org/
Wine for Ubuntu only has packages for i386 and amd64 systems.
The Raspberry Pi is armhf, and would require some experimenting and compiling and even then, not all apps may work.
Bear in mind that Win32 apps are designed for i386 and amd64 systems.
