Added menu to top bar
While exploring some the the options I added an option that displays the menu of the active window in the The MATE Panel 1.12.2
I'm unable to find where I added this option so I can remove it. It doesn't work in all cases - ie FireFox
On the panel right click and remove Topmenu. it’s a panel applet
Thanks @ramblinman41 that did the trick!
I assumed incorrectly that I had to undo the action in the place that I had applied
