Hello,
Is there a way to add items to the context menu in pluma.
I'm using pluma 1.20.1
Currently, when you right-click within the text editor, a pop-up window appears with these options:
Is there a way to add an item to the list. I'm attempting to add a python plugin for pluma. Gedit adds a comment code/uncomment code to it's context menu when selecting the code comment plugin. I want to do the same thing for pluma.
Any feedback would be appreciated. Thanks.
h.
