Aggressive Reaction to ARP
as I often do check out and try different packages I went down the arp rabbit hole and discovered a mean little package named "arping" and when installing it becomes very unreasonable and just a tad to aggressive for me to complete the install.
I'm not sure the trade off is worth the install what do you think?
Hello Blank
Is your concern about meta-packs?
https://help.ubuntu.com/community/CommonQuestions#Meta-packages:_ubuntu-desktop
No, the problem to me is the removing of
ubuntu-mate-core
ubuntu-mate-desktop
just to install this tiny little package. I don’t know why I would wan’t to do that.
Is that not a bit over the edge?
I think this would completely destroy my OS once rebooted.
Ubuntu-mate-core and ubuntu-mate-desktop are meta-packs.
And their are a lot of packages that trigger meta-package removal. Example:
http://packages.ubuntu.com/xenial/ubuntu-mate-desktop
Remove any “depends” package and the meta-pack will be removed.
https://help.ubuntu.com/community/MetaPackages
Thanks v3xx for the explanation and the new knowledge.
I just amused the worst! or maybe it’s just me being cautious, and thinking my cpu will explode into a billion pieces if I pressed the Red Button!
Nope, the operator will always explode first :grin:
Later :wave:
