Is there an alternative to Brasero ?
I could not find gnomebaker as it is no longer in the repositories.
Even though k3b is a KDE app, it seems to work well with gnome/xfce.
thanks a lot.
Brasero would not make CD copies but k3b worked great.
I had this issue when I was trying to burn bluray disks.
Turns out Brasero didn’t have the update to the 17.* ubuntu versions.
I messaged the developer and he said he’s working on it, not sure if this is related to your issue but I thought it worth mentioning.
Hello. You could try xfburn.
Thanks guys for the help.
