Ambiant Mate Dark theme issue when using MATE Advanced Menu
I’d be grateful if other people could check this ;
Issue :
Ambiant Mate Dark theme issue when using MATE Advanced Menu in keyboard mode only.
Overview :
When using the Mate Advanced menu with keyboard only on the Ambiant-Mate-Dark theme, the caret selection field (essentially the highlighted outline or field that shows what menu option is currently active) isn’t visible (it is visible if you hover over with mouse). The usual Applications/Places/Systems menus don’t have this issue.
I’ve switched to another theme for the time being (which is a shame), - if there’s a chance that this could be patched, it would make a huge difference to usability.
Please file this issue on the Ubuntu MATE themes issue tracker :slight_smile:
[quote] Please file this issue on the Ubuntu MATE themes issue tracker :slight_smile:
https://github.com/flexiondotorg/ubuntu-mate-themes
[/quote]
Done! :slight_smile: And the link’s been noted for future reference. Thanks for the heads-up!
