RockT
22 January 2018 10:33
1
Hi all,
I’m using MATE 17.10 with stock ambiant theme at work.
I like it very much but when it comes to QT and JAVA Apps there are some serious problems:
Eclipse has now white fonts on very light background in “git commit and push”.
QT apps’ menu is white font on very light background
SAP Java client has same problems
Is there a way to fix this?
Thx
Rainer
So, not sure. You should raise a bug against the ubuntu-mate-artwork
package.
terzag
23 January 2018 17:09
3
Does it happen with various versions of Qt (i.e. Qt3, Qt4 and Qt5 apps) or only apps using a specific version? or even specific apps? Do you have a ~/.config/Trolltech.conf file with the option style=GTK+ in it?
RockT
16 February 2018 10:09
4
This was my work pc and I got a new one. So I just did a complete reinstall.
Everything is back to normal and I cannot recreate the problem here.
I guess there was some wierd QT config file somewhere.
Thx
Rainer
