i am a using ubuntu mate 17.04 in a vmware which is installed on windows 10 and it’s doing very good, but the only problem that i have now is, i am unable to install 3rd party apps like AMPPS. i checked all the apps that are under welcom page in software and they are very great and easy to install but others like AMPPS requires permission from sudo.
I open the terminal { ctrl+alt+T } and it open like this { mlamleli@ubuntu:~$ } then i wrote { sudo ./Ampps-<3.6>-.run }as a way to install Ampps and i give me this answer { bash: 3.6: no such file or directory}
Even other apps receive the same answer.
all i wish to understand is everything about sudo and how to become a memeber of this group so that i can be able to install and work on Ampps.
Thank you
