I have just noticed that Deja Dup will not perform a backup. Error msg:
"Backup Failed Could not understand duplicity version."
It says it backed up 4 days ago.
Also, I tried to update. Software updater informed me that I "stopped the check for updates". I did not.
Software Boutique tells me :
<An unhandlable error occured
There seems to be a programming error in aptdaemon, the software that allows you to install/remove software and to perform other package management related tasks.>
Error details:
<[Errno 2] No usable temporary directory found in ['/tmp', '/var/tmp', '/usr/tmp', '/home/hld']>
I have been away and have not logged on to this machine in about a week. I am the only user. I am a casual user and not very technical.
Any ideas? Should I simply use the last restore point?
