Auto-resize not working
I just reinstalled 15.04 beta 1 to fix an error with the first install. Now when I more an app to the side of the screen, it does not automatically resize. I like that feature. Any idea why it is not working?
Not sure but make sure that it is enabled under system > preferences > look and feel > windows
Will be a check box titled window tiling or something similar
It's checked, but not work.
Hi John,
push the window upwards holding the mouse down and it should go to full size!. :smiley:
Thanks. It works now.
