[myname]@[myname]s-b550-pc:~/Desktop/r8125-9.004.01$ sudo ./autorun.sh
Check old driver and unload it.
Build the module and install
./autorun.sh: 31: make: not found
how do i fix this first time using linux on desktop aside from a vm
It seems you don't have 'make' so "sudo apt install build-essential"
E: Unable to locate package build-essential
What distro are you on? I tested on UM20.04 I can install that package.
