Barracuda Copy icon not showing Properly
Just loaded Barracuda Copy program to Mate 15.10. All seems to work, Syncing with Cloud and new Copy Folder, but the Copy icon in the top panel is showing an “X”. Anyone else experience that?
Thanks
sounds like the icon set you are using doesn’t have one for that application. What icons are you using, the default?
Yes - Just the Default icons.
thx
I went ahead and downloaded and installed the application. The icon is showing in top right just fine for me. I am using the default panel layout. I would try reinstalling.
I’ll give it a try. Thanks
