Battery icon position issue
Hi to all, in my fresh installation of Ubuntu Mate 16.10, i’ve noted the battery icon in panel has a bad position (Screenshot).
Is it a bug or is there a way to fix it?
Thank you
I think thats more to do with the way the icon theme is, changing icon theme might give you a better look?
No it doesn’t. Since using all the other icon themes in the system, the battery icon doesn’t change.
I don’t have a link at hand, but I do remember seeing this being reported as a bug and the cause was wrong icon dimentions, if I remember correctly. But yes, it’s a known issue and will get fixed.
Oh, found it: https://bugs.launchpad.net/ubuntu-mate/+bug/1639525
