I run BleachBit, check every box under Firefox, start Firefox, click on new tab and see all my history. If I clear Firfox history from the Firefox menu, then hit new tab, there is no history displayed. So does BleachBit intentionally leave behind Firefox history?
have you tried running it as sudo in a terminal?
No, but will next time.
So I just checked Bleachbit (as root). It does not provide the option to delete Firefox files.
Can you tell me your current distro and Bleachbit version.
BleachBit version 2.0
from the applications menu or ‘sudo bleachbit’ in a terminal?
