Hi All…
I occasionally use bluetooth to transfer small files between between my smartphone (Samsung Galaxy S5) and laptops, however I have been having some issues recently. I was initially unable to pair any device to my new Entroware Apollo laptop running Ubuntu MATE 17.10. After installing the “bluetooth” package I was able to pair it with my older laptop (A lenovo B590 running Debian Stretch with the Cinnamon Desktop). I am still unable to pair my phone to the Entroware laptop though. The issue is that the popup that should give me the option to allow the pairing isn’t showing up on Ubuntu MATE. Has anyone experienced a similar issue or know how I might go about fixing this?
Regards,
Jay
Ps. Here’s the output of inxi on the Entroware if it helps…
~ » inxi -v7 ~
System: Host: ElectricalBrain Kernel: 4.13.0-19-generic x86_64
bits: 64 gcc: 7.2.0
Desktop: MATE 1.18.0 (Gtk 3.22.25-0ubuntu0.1) info: mate-panel dm: li
ghtdm
Distro: Ubuntu 17.10
Machine: Device: laptop System: Entroware product: Apollo v: R3 serial: N/A
Mobo: Entroware model: Apollo v: R3 serial: N/A
UEFI: American Megatrends v: 1.05.09E date: 11/03/2017
Chassis: Notebook type: 10 serial: N/A
Battery BAT0: charge: 35.9 Wh 100.0% condition: 35.9/35.3 Wh (102%)
volts: 13.0/11.4
model: Notebook BAT Li-ion serial: 0001 status: Full cycles: 0
CPU: Dual core Intel Core i7-7500U (-HT-MCP-)
arch: Kaby Lake rev.9 cache: 4096 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11616
clock speeds: min/max: 400/3500 MHz 1: 2900 MHz 2: 2900 MHz
3: 2900 MHz 4: 2900 MHz
Memory: Using dmidecode: root required for dmidecode
Graphics: Card: Intel HD Graphics 620 bus-ID: 00:02.0 chip-ID: 8086:5916
Display Server: x11 (X.Org 1.19.5 )
drivers: modesetting (unloaded: fbdev,vesa)
Resolution: [email protected]
OpenGL: renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2)
version: 4.5 Mesa 17.2.2 (compat-v: 3.0) Direct Render: Yes
Audio: Card Intel Device 9d71
driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d71
Sound: Advanced Linux Sound Architecture v: k4.13.0-19-generic
Network: Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
driver: r8169 v: 2.3LK-NAPI port: e000
bus-ID: 3a:00.1 chip-ID: 10ec:8168
IF: enp58s0f1 state: down mac: 80:fa:5b:46:08:b9
Card-2: Intel Wireless 8265 / 8275
driver: iwlwifi bus-ID: 3b:00.0 chip-ID: 8086:24fd
IF: wlp59s0 state: down mac: f8:59:71:0f:f9:06
WAN IP: None Detected!
IF: enp58s0f1 ip-v4: N/A ip-v6-link: N/A
IF: wlp59s0 ip-v4: N/A ip-v6-link: N/A
Drives: HDD Total Size: 1015.8GB (8.3% used)
ID-1: /dev/sda model: WDC_WDS100T1B0A size: 1000.2GB
serial: 164800423801
ID-2: USB /dev/sdb model: Cruzer_Edge size: 15.6GB
serial: 4C530001260227113380-0:0
Optical: No optical drives detected.
Partition: ID-1: / size: 916G used: 78G (9%) fs: ext4 dev: /dev/sda2
label: N/A uuid: 48fe3066-e13f-4817-a62f-f56e5719a773
ID-2: /boot/efi size: 511M used: 4.6M (1%) fs: vfat dev: /dev/sda1
label: N/A uuid: 403B-0677
ID-3: /media/jay/AC65-D451 size: 15G used: 1.5G (10%)
fs: vfat dev: /dev/sdb1 label: N/A uuid: AC65-D451
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Unmounted: No unmounted partitions detected
Sensors: System Temperatures: cpu: 38.5C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 179 Uptime: 10 min Memory: 606.2/15964.9MB
Init: systemd v: 234 runlevel: 5 default: graphical.target
Gcc sys: 7.2.0
Client: Shell (zsh 5.2 running in terminology) inxi: 2.3.37
