Brisk menu fails to start after every reboot with an error message
but works normally if deleted and added again to the panel. Any solution please help...
At this stage, it could be caused by almost anything -- from a mis-installed system file to simply having a CPU with too many cores.
Have you noticed any "System Problem Report" or crash dialogs pertaining to the Brisk menu? If so, then the crash reports would be interesting to see.
Upload the contents of the .xsession-errors
file in your home directory (it's a hidden file, so press Ctrl-H in the file manager to show hidden files). Select the contents of .xsession-errors
that you paste here and click the </>
icon in the post preview panel before you submit your reply. It is very hard to read such text otherwise.
TIA.
Dear Sir @gordon,
i am sorry for the delayed response. And here is the content of that error file:
dbus-update-activation-environment: setting DBUS_SESSION_BUS_ADDRESS=unix:path=/run/user/1000/bus
dbus-update-activation-environment: setting DISPLAY=:0
dbus-update-activation-environment: setting XAUTHORITY=/home/mack87dash/.Xauthority
dbus-update-activation-environment: setting GTK_MODULES=appmenu-gtk-module:gail:atk-bridge:canberra-gtk-module
dbus-update-activation-environment: setting QT_ACCESSIBILITY=1
dbus-update-activation-environment: setting SHELL=/bin/bash
dbus-update-activation-environment: setting XDG_CONFIG_DIRS=/etc/xdg/xdg-mate:/etc/xdg
dbus-update-activation-environment: setting XDG_SESSION_PATH=/org/freedesktop/DisplayManager/Session0
dbus-update-activation-environment: setting GTK_IM_MODULE=ibus
dbus-update-activation-environment: setting LANGUAGE=en_IN:en
dbus-update-activation-environment: setting QT4_IM_MODULE=ibus
dbus-update-activation-environment: setting LC_ADDRESS=en_IN.UTF-8
dbus-update-activation-environment: setting LC_NAME=en_IN.UTF-8
dbus-update-activation-environment: setting XMODIFIERS=@im=ibus
dbus-update-activation-environment: setting DESKTOP_SESSION=mate
dbus-update-activation-environment: setting LC_MONETARY=en_IN.UTF-8
dbus-update-activation-environment: setting PWD=/home/mack87dash
dbus-update-activation-environment: setting XDG_SESSION_DESKTOP=mate
dbus-update-activation-environment: setting LOGNAME=mack87dash
dbus-update-activation-environment: setting QT_QPA_PLATFORMTHEME=gtk2
dbus-update-activation-environment: setting XDG_SESSION_TYPE=x11
dbus-update-activation-environment: setting GPG_AGENT_INFO=/run/user/1000/gnupg/S.gpg-agent:0:1
dbus-update-activation-environment: setting XDG_GREETER_DATA_DIR=/var/lib/lightdm-data/mack87dash
dbus-update-activation-environment: setting LD_PRELOAD=libgtk3-nocsd.so.0
dbus-update-activation-environment: setting GDM_LANG=en_US
dbus-update-activation-environment: setting HOME=/home/mack87dash
dbus-update-activation-environment: setting IM_CONFIG_PHASE=1
dbus-update-activation-environment: setting LC_PAPER=en_IN.UTF-8
dbus-update-activation-environment: setting LANG=en_IN
dbus-update-activation-environment: setting XDG_CURRENT_DESKTOP=MATE
dbus-update-activation-environment: setting XDG_SEAT_PATH=/org/freedesktop/DisplayManager/Seat0
dbus-update-activation-environment: setting GTK_CSD=0
dbus-update-activation-environment: setting CLUTTER_IM_MODULE=ibus
dbus-update-activation-environment: setting XDG_SESSION_CLASS=user
dbus-update-activation-environment: setting LC_IDENTIFICATION=en_IN.UTF-8
dbus-update-activation-environment: setting GTK_OVERLAY_SCROLLING=0
dbus-update-activation-environment: setting USER=mack87dash
dbus-update-activation-environment: setting SHLVL=1
dbus-update-activation-environment: setting LC_TELEPHONE=en_IN.UTF-8
dbus-update-activation-environment: setting QT_IM_MODULE=ibus
dbus-update-activation-environment: setting LC_MEASUREMENT=en_IN.UTF-8
dbus-update-activation-environment: setting UBUNTU_MENUPROXY=1
dbus-update-activation-environment: setting PAPERSIZE=a4
dbus-update-activation-environment: setting XDG_RUNTIME_DIR=/run/user/1000
dbus-update-activation-environment: setting COMPIZ_CONFIG_PROFILE=mate
dbus-update-activation-environment: setting LC_TIME=en_IN.UTF-8
dbus-update-activation-environment: setting XDG_DATA_DIRS=/usr/share/mate:/usr/local/share:/usr/share:/var/lib/snapd/desktop
dbus-update-activation-environment: setting PATH=/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
dbus-update-activation-environment: setting GDMSESSION=mate
dbus-update-activation-environment: setting LC_NUMERIC=en_IN.UTF-8
dbus-update-activation-environment: setting _=/usr/bin/dbus-update-activation-environment
** Message: 15:26:02.741: couldn't access control socket: /run/user/1000/keyring/control: No such file or directory
Window manager warning: Log level 128: unsetenv() is not thread-safe and should not be used after threads are created
Window manager warning: Log level 128: Name com.canonical.AppMenu.Registrar does not exist on the session bus
** (mate-settings-daemon:1267): WARNING **: 15:26:09.456: Error in setting scroll method on "SynPS/2 Synaptics TouchPad"
current session already has an ibus-daemon.
(process:1454): indicator-sound-WARNING **: 15:26:18.547: volume-control-pulse.vala:744: Unable to connect to dbus server at 'unix:path=/run/user/1000/pulse/dbus-socket': Could not connect: No such file or directory
(caja:1330): Gtk-WARNING **: 15:26:19.498: Failed to register client: GDBus.Error:org.gnome.SessionManager.AlreadyRegistered: Unable to register client
WARNING:root:can not import unity GI Namespace Dbusmenu not available
** (process:1335): WARNING **: 15:26:23.217: could not find the desktop file for 'org.gnome.Calendar.desktop'
(process:1335): Indicator-Datetime-WARNING **: 15:26:23.477: Unrecognized TZID: 'Etc/Utc'
(process:1335): Indicator-Datetime-WARNING **: 15:26:23.478: Unrecognized TZID: 'Etc/Utc'
blueman-applet 15.26.28 WARNING PluginManager:147 __load_plugin: Not loading PPPSupport because its conflict has higher priority
blueman-applet 15.26.29 WARNING PluginManager:147 __load_plugin: Not loading DhcpClient because its conflict has higher priority
INFO:root:The HUD is disabled via org.mate.hud in gsettings.
Traceback (most recent call last):
File "/usr/bin/blueman-tray", line 40, in <module>
BluemanTray()
File "/usr/lib/python3/dist-packages/blueman/main/Tray.py", line 14, in __init__
check_single_instance("blueman-tray")
File "/usr/lib/python3/dist-packages/blueman/Functions.py", line 306, in check_single_instance
os.remove(lockfile)
FileNotFoundError: [Errno 2] No such file or directory: '/home/mack87dash/.cache/blueman-tray-1000'
** (mate-screensaver:1497): WARNING **: 15:26:45.450: screensaver already running in this session
RuntimeError: object at 0x7fb3d6ad4340 of type FolderColorMenu is not initialized
RuntimeError: object at 0x7fb3d6b0a680 of type RenameMenu is not initialized
blueman-applet 15.26.54 WARNING DiscvManager:109 update_menuitems: warning: Adapter is None
** (mate-panel:1309): CRITICAL **: 15:29:04.507: panel_drawer_custom_icon_changed: assertion 'drawer->button != NULL' failed
** (mate-panel:1309): CRITICAL **: 15:29:04.508: panel_drawer_custom_icon_changed: assertion 'drawer->button != NULL' failed
Window manager warning: Log level 128: Name com.canonical.AppMenu.Registrar on the session bus is owned by :1.87
GDBus.Error:org.freedesktop.DBus.Error.UnknownMethod: No such interface “com.canonical.AppMenu.Registrar” on object at path /com/canonical/AppMenu/Registrar
Window manager warning: last_user_time (43539415) is greater than comparison timestamp (461479). This most likely represents a buggy client sending inaccurate timestamps in messages such as _NET_ACTIVE_WINDOW. Trying to work around...
Window manager warning: 0x1200003 (Top Panel) appears to be one of the offending windows with a timestamp of 43539415. Working around...
Window manager warning: last_user_time (43539415) is greater than comparison timestamp (463289). This most likely represents a buggy client sending inaccurate timestamps in messages such as _NET_ACTIVE_WINDOW. Trying to work around...
Window manager warning: last_user_time (43539415) is greater than comparison timestamp (465733). This most likely represents a buggy client sending inaccurate timestamps in messages such as _NET_ACTIVE_WINDOW. Trying to work around...
Window manager warning: Log level 16: Visible region is null
File "/usr/share/caja-python/extensions/dejadup.py", line 156, in get_file_items
include_paths = self.dejadup.get_dejadup_paths('include-list')
File "/usr/share/caja-python/extensions/dejadup.py", line 70, in get_dejadup_paths
paths = ast.literal_eval([stdout][0]) # Convert shell dump to list
File "/usr/lib/python3.8/ast.py", line 99, in literal_eval
return _convert(node_or_string)
File "/usr/lib/python3.8/ast.py", line 98, in _convert
return _convert_signed_num(node)
File "/usr/lib/python3.8/ast.py", line 75, in _convert_signed_num
return _convert_num(node)
File "/usr/lib/python3.8/ast.py", line 66, in _convert_num
_raise_malformed_node(node)
File "/usr/lib/python3.8/ast.py", line 63, in _raise_malformed_node
raise ValueError(f'malformed node or string: {node!r}')
ValueError: malformed node or string: b"['$HOME']\n"
