Bumblebee doesn't work?
i installed bumblebee in ubuntu mate 16.04 LTS
$sudo apt-get install bumblebee bumblebee-nvidia primus linux-headers-generic
and when i tried to run $optirun firefox it gave me the following output :
[ 916.390458] [ERROR]Cannot access secondary GPU - error: [XORG] (EE)
[ 916.390513] [ERROR]Aborting because fallback start is disabled.
so,any solution for that.
See the post below titled “Bumblebee not working after upgrade to 16.04” for a fix.
thanks alot .
do you know how can i delete my post ?
Hi @ahmed751995,
there should be a trashcan (dustbin) symbol by the reply button under each post!. :smiley:
