Caja-actions restoring order
Hi community,
Find caja-actions a very useful and customizable option. Very happy.
Since I directly restore from backup caja-actions to ~/.local/share/file-manager/actions, the actions appears indeed, but mixed in the menu, then I must patiently re-order in configuration tool and always reboot. Things get worse when includes sub-menus, and sub-sub-menus...
Same situation when I export and import later from caja-actions assistant. Looking by dconf didn't success for me... so is there a way to restore it and preserve the previous order and menus and subs-? Would be a relief and a save of time :wink:
Many thanks
Sorry, I forgot to save ~/.config/caja-actions/caja-actions.conf updated according to new actions created and changed some days later. Then save:
is enough to restore caja-actions completely with full actions in correct order.
