Caja context menus and "Beyond Compare" (Ubuntu Mate 16.10)
I’m trying to get the Beyond Compare context menus working in Caja. There seems to be a dedicated .so file for this but I can’t work out where to put it/how to make it work. I’ve tried putting it in lots of places without success.
Any ideas would be most welcome!
My old laptop died a couple of weeks ago and as I don’t like the current gnome interface I decided to try Ubuntu Mate on the new one rather than kludging the standard Ubuntu installation to look/behave the same like I’ve done before. Wasn’t expecting problems like this…
memascii.
I don't know if you're aware of 'meld' or not, it's a visual diff program and quite solid.
Never heard of "Beyond Compare" before, but Caja supports scripting if you care to roll your own.
In case anybody else is struggling with this, you just need to copy the extension lib to:
/usr/lib/x86_64-linux-gnu/caja/extensions-2.0/bcompare-ext-caja.so
That worked for me at least.
Cheers.
Memascii
