Caja default settings
Tried to remove the switching option for path-address bar in caja but if untick just remove all the breadcrumbs, is there any way to just remove his option I will be confortable just with any one those either showing the route path or the address in the bar, but I dont need this icon (btw I wasnt able to find whether it belongs to a mate, gnome or hicolor theme) nor the switching option itself.
Many tks for your fedback
amgpuma
