Caja location bar suggestions
Hi. A question about Caja: when typing directory addresses in the location bar it only seems to make suggestions when there’s an exact match. If there are several possibilities it doesn’t list them like other file managers do. Example: I want to go to the Documents folder, so I type “/home/user/Do” but it won’t suggest Documents and Downloads (the two folders beginning with “Do”). However if I type “/home/user/Doc” in the location bar it will inmediately suggest “Documents” and I can press Tab and Enter to go to it. It should make suggestions as I type and if there are several possible matches it should list them in some order. Is this feature really not available in Caja, not even in later versions? thanks
