I’ve installed xbindkeys and in the ~/.xbindkeysrc
I have the following binds
"firefox"
Mod2+Mod4 + 1 + Release
"caja"
Mod4+2 + Release
"mate-terminal"
Mod4 + 3 + Release
The terminal and Firefox work, Caja doesn’t. Unless I restart xbindkeys: killall xbindkeys && xbindkeys
So for some reason it doesn’t work on boot.
So I tried too check if caja can be found
"whereis caja >> /home/janw/caja.txt && caja"
Mod4+2 + Release
But it always logs the same , before and after restarting it or running it manual.
I tried different programs, different key binds. Only caja appears to be a problem.
Does anybody have an idea where to look next?
