Caja - right-click options - filetype context - install font
Is there any possibility that an extension could be created such that
a) go to folder containing various fonts,
b) select group of multiple TTF files for different typefaces for a given Font family, then
c) have Caja initiate the font installation process as a single-action task for the (for example) 21 font files related to DejaVu font ?
I just installed the Caja file-actions and file-manager extensions and don't see such an option available.
