Hi guys, most of my daily work is connecting to remote machines and do work there.
Caja worked great for it until 20.04 but since I upgraded to 22.04 I started having issues.
I cannot rename files, copy or cut them, but moving a file into a folder for instance keeps working.
Right click context menu is also different.
When I kill caja, unmount ssh and reconnect, everythign starts to work again.
Sorry if you're already aware of this or asked before, is there anyone else having such issues?
Thanks,
