Can not get microphone to work
I have 2 microphones, one with my Lifecam and another one.
But I can not use the non-Lifecam microphone?
How can I use that one?
HD-Audio Generic        F1:  Help               │
│ Chip: Realtek ALC887-VD
card 1: Generic [HD-Audio Generic], device 0: ALC887-VD Analog [ALC887-VD Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: Generic [HD-Audio Generic], device 2: ALC887-VD Alt Analog [ALC887-VD Alt Analog]
  Subdevices: 1/1
card 2: HD5000 [Microsoft® LifeCam HD-5000], device 0: USB Audio [USB Audio]
  Subdevices: 1/1
Hello fixit7
This is an old trick, but it sometimes solves problems:
  • Plug the microphone into your computer and switch it on, before booting your computer.
:slightly_smiling_face:
It turned out that the mic connector was a bit persnickety. After unplugging it and re plugging it in, it started working.
I thought about replacing the connector, but it is part of the motherboard.
The front connector works fine all the time.
