Lxr
15 February 2019 12:14
1
Dear friends I can't seem to install a driver on my computer. Getting an error saying this
~/Desktop/TL-WN823N(US)_V3_160315_Linux/Driver$ sudo make
"NO SKRC,we will use default KSRC"
make ARCH=x86_64 CROSS_COMPILE= -C /lib/modules/4.10.0-42-generic/build M=/home/alex/Desktop/TL-WN823N(US)_V3_160315_Linux/Driver modules
/bin/sh: 1: Syntax error: "(" unexpected
Makefile:1696: recipe for target 'modules' failed
make: *** [modules] Error 2
kc1di
15 February 2019 21:32
2
most wireless drivers do not need to be built and installed like that.
What is the wireless card in that machine?
Lxr
16 February 2019 01:04
3
It is TP link usb and it needs a driver otherwise it don't work. This driver I downloaded from tp-link website it is for linux but I can't run it as you can see from above error. Please help I cant find any useful info from other forums.
kc1di
16 February 2019 09:29
4
Lxr:
TL-WN823N
Ok here is what you need to do if you can connect to the internet via Ethernet cable.
sudo apt-get install git linux-headers-generic build-essential dkms
git clone GitHub - Mange/rtl8192eu-linux-driver: Drivers for the rtl8192eu chipset for wireless adapters (D-Link DWA-131 rev E1 included!)
cd rtl8192eu-linux-driver
sudo dkms add .
sudo dkms install rtl8192eu/1.0
reboot wifi should be working.
Good Luck.
