Cannot scroll All the way up when using 'dpkg -l'
I go to list all packages using ‘dpkg -l’
I use shift and page up to scroll up, but I cannot scroll past a certain program.
I would like to be able to see all the programs.
‘dpkg -l | less’
use enter to scroll down
Hi @rbohling. In the first case I think you're running into the scroll limit of mate-terminal but it can be increased from default of 512. I usually run about 10000.
Your " | less" solution is good, too.
I like your solution a lot better. Thanks Bill.
Here I prefer Scrollback - Unlimited as I have 4-32 Gb of RAM :slight_smile:
