I followed your method.
Still can’t boot it.
@fixit7: Ate my own dogfood: I downloaded the ISO file, created a bootable USB stick with dd using the steps outlined above. Bootable stick was created ok - technically - so nothing wrong with the dd advice given. Only that it doesn’t 's boot. So you were right about that one.
I mounted the ISO using loop device and took a look at what’s inside.
First finds: it uses Isolinux (Syslinux) boot loader and all files were from year 2012, apart from autorun.*, which were from 2011. I stopped right there.
Hell must freeze over before I let something as mission critical as system backups be handled by software that was last updated 4.5 years ago. Period.
My free tip of the day: we use review sites when thinking about buying something (a new car, fridge, computer, booking a hotel) because it makes sense to learn from other people’s (possible) mistakes. Do the same with software.
If a software project has its code hosted at Sourceforge, Github etc. do take a look, even if they have a separate homesite (a flashy “marketing site”). Check when the last commit was made, how many bugs / issues are open and are bugs / issues being handled in a timely manner (check the closed ones). Doing this saves a lot of your time, not to mention blood, sweat and tears.
You’re better off using Clonezilla.
I’m always interested in failures having had many of my own - and have mostly learned from them.
I downloaded the redobackup-livecd-1.0.4.iso from sourceforge.net and used MATE’s Startup Disk Creator to make a bootable USB key. After rebooting, and selecting boot from USB, I got a message saying something like no bootable partition found… and was dropped into grub and then back into MATE.
Maybe the iso could be used to make a bootable CD? I’m finished following this particular rat down its’ hole however. Clonezilla is better for sure.
Redo seems to want to know if it’s users experience difficulties. Perhaps the OP will contact them?
Edit: I tried another tack. This time, after using GParted to reformat the USB key to fat 32, I used UNetbootin to create a “bootable” USB key from the iso. But before rebooting, I opened GParted to see if there was a boot flag set on the “bootable” USB. There was not. So I set the boot flag using GParted and rebooted, selecting boot from USB. I saw a UNetbootin menu and selected Redo backup and then was in Redo. That’s as far as I went - the USB key was bootable.
So I wasn’t exactly finished following this rat. I got a better ending however…
Yes, in their download page they do say it’s a CD image and outline steps for using UNetbootin if you want to create a bootable USB stick directly, without burning a CD first. I didn’t feel like spending more time with it though, after seeing what was inside. It’s a pity, really - the concept was/is great.
No problem.
Clonezilla works great.
Thanks for taking to time to test it out.
I will stick with Clonezilla.
Someone got it to work, but it has to be done with Windows.
Does not change my mind about not using Redo Backup.
Redo Backup can NOT be put on a pen drive. (Despite what their
webpage says.)
I'm downloading it as we speak. redobackuplivecd1.0.4 I'm going to
fire up Rufus v2.12p in Windows XP to load this pendrive (4gig USB
stick, generic stick at that) and test the results. gimmie a few
here...
Results are as follows. Ran Rufus, selected iso; left everything else
untouched. (created using ISO method, didn't even have to use DD!)
Put USB stick into Acer laptop, started machine. It loaded just fine!
Picked up network card, too! So, I could at this point, 'clone' this
machine to another box on this network. ■■■■ easy program to use,
too.
this might actually be a keeper. I didn't try this with tuxboot,
because I don't think? it's on my linux boxes, but.. I'll check it
out later just to see if that might be your issue.
Anyways, using rufus v2.12p (portable) in iso mode does work fine.
I edited the how-to post earlier in this thread and added instructions on how to format the USB stick using command line tools, once you want to return the stick to regular data use.
I also made a change to the original “Make bootable USB stick” instructions replacing udisksctl power-off -b /dev/sdc with _eject -v /dev/sd_c because if your stick is plugged into a hub, the udisksctl power-off command may power down the hub also, which most likely is not what you want if you have other devices plugged into it.
