router cisco, the red not have problem, just me at the problem
Cisco soho or Enterprise?
the router is cisco enterprise
So. Let’s see. Your port is on no suthdown because you can ping the router, you have or have not vlans but again you can ping others pc,s. Can you redo the condig and change the port from the router? The last thing you can do is to make a ubuntu usb and boot from it to see if that works. I just finished my cisco ccna4 curse but noting it’s coming to my mind on what the problem its.
with live usb dont work
If you ping 8.8.8.8?
ready, but dont working
In linux mint or ubuntu 16.04 you have the same problem? Sorry i am trying to find the problem and see if its a os or router issue
live usb with linux mint, i have the problem too
The problem is with the configuration from the router or the os. Try again from scratch
with windows 10 have the same problem
So the problem it’s the router configuration. Did you config nat on the router?
Can you also post output of the command:
route -n
