I am unable to install NaSC the math for humans software from elementary OS.
The terminal gives the following errors:
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
nasc : Depends: libgranite3 (>= 0.2.0) but it is not installable
With synaptic it gives:
I followed the regular instructions of adding ppa updating and installing.
instructions
firstly, you have “broken packages”, to fix that, run the following terminal command (Ctrl +Alt + t):
sudo dpkg --configure -a
followed by
sudo apt-get install -f
“unmet dependencies”, to cure that, try changing your software sources download location to “Main server” (Where it states “Download from”).
Update your system sources list with:
sudo apt-get update
You can look for the packages here if the above doesn’t help and install them before you try and install the package (NaSC) again (make a note of the package name and search for the Ubuntu packages!):
http://pkgs.org/
Let us know how you get on!.
This is what i get after following your steps
Please do
sudo dpkg – configure -a
the problem is package dependencies
please install libgranite stable version
Regards,
Christian
http://cloudappsportal.com/
