Cant turn sound on from top panel
This just happened, turning on after a power outage, which shouldn’t have caused this.
My Sound icon in the top panel is greyed out, with the Mute box checked, which won’t uncheck. I cannot use the slider to enable the volume. Loading pavucontrol-qt gave me:
“Connection to PulseAudio failed. In this case it is likely because PULSE_SERVVER in the Environment/X11 Root Window Properties or default…”
It went on to say that I should run start-pulse-audio-x11 manually. start-pulseaudio-x11 Connection failure: Connection refused pa_context_connect() failed: Connection refused
Can anyone please tell me what the fark is going on?
Can’t tell you much. Have you yet rebooted?
try starting pulseaudio direct, not from bash start script
pulseaudio -v
it should tell you about any errors to investigate
also try deleting user settings files in /.config/pulse
reboot and pulseaudio will rebuild default user configuration files
Starting pulseaudio got me an error message.
I “solved” my problem by reinstalling the system. From a USB, installation takes ~30 minutes, then driver installation, a reboot, and installing software from the wonderful Welcome window.
I DO still have the *&%&$^& fake battery warning, and MW said on Launchpad that he couldn’t reproduce the error. If HE can’t figure it out…
Sigh.
