I was just curious if I could change the lock screen background. Changing it in lightdm only works while not logged in to a particular user. Thanks!
It is possible. It's a security risk adding the option to MATE Tweak as the lock screen runs with elevated privileges..
There are some instructions provided there you may wish to try:
- Create
/usr/share/glib-2.0/schemas/zubuntu-mate-lock-background.gschema.override
that includes a section like this:
[org.mate.background]
picture-filename='fullpath-to-lockscreen-image.jpg'
- Run
glib-compile-schema /usr/share/glib-2.0/schemas
I went a more lazier route and changed the original image:
/usr/share/backgrounds/ubuntu-mate-common/Ubuntu-Mate-Cold.jpg
If you opt for my method, the easiest way would be to navigate to the folder and open it as root from the right-click menu, and then replace the image.
