Cheese keeps taking pictures by itself.
How can I stop that?
Reinstall. Either your PC is hacked or you caused this by tweaking.
Either way the safe course of action is to assume compromise.
I re-installed it.
Still taking pictures without any action by me. ??
Is there any program?
Guvcview is doing the same thing.
What the heck is going on?
use sudo netstat -putona
to see if cheese is making a connection.
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name Timer
tcp 0 0 127.0.1.1:53 0.0.0.0:* LISTEN 1027/dnsmasq off (0.00/0/0)
tcp 0 0 127.0.0.1:631 0.0.0.0:* LISTEN 4282/cupsd off (0.00/0/0)
tcp 0 0 127.0.0.1:25 0.0.0.0:* LISTEN 1451/master off (0.00/0/0)
tcp 0 0 127.0.0.1:9050 0.0.0.0:* LISTEN 1007/tor off (0.00/0/0)
tcp 0 0 192.168.1.2:42202 69.147.86.11:443 ESTABLISHED 3910/seamonkey off (0.00/0/0)
tcp 0 0 192.168.1.2:60616 104.18.44.87:443 ESTABLISHED 3910/seamonkey off (0.00/0/0)
tcp 0 0 192.168.1.2:59992 51.15.65.104:9001 ESTABLISHED 1007/tor off (0.00/0/0)
tcp 0 0 192.168.1.2:58418 62.210.123.24:443 ESTABLISHED 1007/tor off (0.00/0/0)
tcp6 0 0 ::1:631 :::* LISTEN 4282/cupsd off (0.00/0/0)
tcp6 0 0 ::1:25 :::* LISTEN 1451/master off (0.00/0/0)
udp 0 0 0.0.0.0:5353 0.0.0.0:* 775/avahi-daemon: r off (0.00/0/0)
udp 0 0 0.0.0.0:44110 0.0.0.0:* 775/avahi-daemon: r off (0.00/0/0)
udp 0 0 0.0.0.0:53065 0.0.0.0:* 1027/dnsmasq off (0.00/0/0)
udp 0 0 127.0.1.1:53 0.0.0.0:* 1027/dnsmasq off (0.00/0/0)
udp 0 0 0.0.0.0:68 0.0.0.0:* 1016/dhclient off (0.00/0/0)
udp 0 0 192.168.1.2:123 0.0.0.0:* 1300/ntpd off (0.00/0/0)
udp 0 0 127.0.0.1:123 0.0.0.0:* 1300/ntpd off (0.00/0/0)
udp 0 0 0.0.0.0:123 0.0.0.0:* 1300/ntpd off (0.00/0/0)
udp 0 0 0.0.0.0:631 0.0.0.0:* 4283/cups-browsed off (0.00/0/0)
udp6 0 0 :::5353 :::* 775/avahi-daemon: r off (0.00/0/0)
udp6 0 0 fe80::2c3d:32b7:3a4:123 :::* 1300/ntpd off (0.00/0/0)
udp6 0 0 ::1:123 :::* 1300/ntpd off (0.00/0/0)
udp6 0 0 :::123 :::* 1300/ntpd off (0.00/0/0)
udp6 0 0 :::45535 :::* 775/avahi-daemon: r off (0.00/0/0)
