First of all, I’m not running Clementine from the official repo. That version is too old and does not fit well with my usage needs and the habits I have acquired since version 1.3.1 came out. I’m running Clementine from the developer’s own PPA from Clementine Official PPA. That brings Clementine to version 1.3.1.
I was wondering if others are experiencing the same problems as I am with Clementine on Ubuntu-Mate 16.04. Clementine 1.3.1 is generally unstable under 16.04 and crashes or freezes after continued use. It used to be rock solid under 14.04, where I was even used to install and run the developer nightly builds PPA. But in 16.04 it has been nothing but pain.
Are you experiencing the same problem? Were you able to fix or circumvent them?
