Colour temp - possible to set 100% manually?
There are threads here about this already - but the search revealed no threads that had info about using the apps for minimizing blue light exposure for different schedules like mine or in any 100% manually controlled ways.
I've tried both Redshift & F.lux & the trick using Gnome Tweak besides, but came into 2 serious problems for me to use any of 'em - namely...
1 - I mostly live a 3rd shift life, and sleep during daylight hours - as in from around sunup 'till 3PM EDT in a fully darkened room;
2 - Ubuntu Mate 18.04.5 seems to fight with these types of apps.
(Yes, I know I'm out of date & hope to upgrade before next week...)
Aside of these vexations, the OS's built-in screen temp adjustment thingy doesn't seem to work at all.
I found lat & long coordinates for McMurdo Station in Alaska:
-77.9527, 166.4895
And presently do use those with f.lux - but it is still not very useful schedule-wise for me.
I also joined & posted my query at the f.lux forum, to no avail.
Emailed the devs of Redshift & gammy as well with my query - no reply from either.
In a perfect world, it would be possible to use something like a tray icon like f.lux has to just switch between unshifted & ~2700k at will, but if such a thing exists I have not found it.
For my situation it would mostly be OK to have it set to ~2700k all the time.
This would be really simple if my display had such a feature built in - but sadly it does not.
Any helpful suggestions will be HUGELY appreciated !!
Hi @computerguy :slight_smile:
Maybe it will help adding this to your redshift config file :
temp-day=3000
temp-night=3000
This should keep a soft colors all day long.
Lower will be the temp inside this configuration, more the screen will be "red" :new_moon: :red_circle:
YAY !! Thanks Very Much Olek !!!
I looked for all config options and found this:
http://jonls.dk/redshift/
Then made the file as described, which has this inside it:
[redshift]
temp-day=2700
temp-night=2700
adjustment-method=randr
;location-provider=manual
; Enable/Disable a smooth transition between day and night
; 0 will cause a direct change from day to night screen temperature.
; 1 will gradually increase or decrease the screen temperature.
transition=0
; Set the screen brightness. Default is 1.0.
;brightness=0.9
; It is also possible to use different settings for day and night
; since version 1.8.
brightness-day=0.7
brightness-night=0.4
;[manual]
;lat=-77.9527
;lon=166.4895
I'll likely try some various settings, but for now this is very, very good & easily disabled instantly if/when I want that colour temp & brightness.
Thanks Again !!
