I've spent hours trying to change the brisk menu icon - partial success in that I can get the graphic I want but it does not display the correct colour. My next change of tack is to look at creating a custom launcher in the panel and having a command in it that will launch brisk. Is there a command I could put in a customer launcher that would launch the menu?
