Computer hangs frequently in ubuntu mate, not having this problem in ubuntu
I was previously using ubuntu, recently switched to ubuntu-mate.
The computer suddenly hangs and my only option to force shutdown by power button.
I was not having this problem in ubuntu , now that i have switched to ubuntu-mate I am having this problem.
I don't know how to even start solving this problem.
I have heard there are logs where we can find info, but no idea how to use it.
Any help appreciated.
When you say you have "switched" to Ubuntu Mate, do you mean you have done a fresh install of Ubuntu Mate or that you have installed the Ubuntu Mate Desktop onto an existing Ubuntu installation?
Hello and welcome!
Actually, I'd like to join to @skyraider256526 's question for my laptop with UM 18.04 suffers hangs/freezes as well. Yesterday it did that twice.
The only (unreliable) clue is that freezing occurs when I'm typing/working with a 'heavy' web single page application like @ UM forum or gitlab.
An advice on how to diagnose the problem and find out its roots is highly appreciated.
Regards,
Gene
yes i have done an fresh install
In my apport log there was error regarding msd-locate-pointer.
What was yours.
Alas, I've failed to find a mere trace of the problem in my logs.
skyraider256526
what version of UM are you on please?
In case its GPU versus shared memory versus low RAM how about you post your
inxi -F
BELOW IS MINE just as example
System: Host: um Kernel: 5.0.0-27-generic x86_64 bits: 64 Desktop: MATE 1.20.4 Distro: Ubuntu 19.04 (Disco Dingo)
Machine: Type: Desktop System: Gigabyte product: H110M-S2H v: N/A serial:
Mobo: Gigabyte model: H110M-S2H-CF v: x.x serial: UEFI [Legacy]: American Megatrends v: F25a
date: 01/11/2018
CPU: Topology: Quad Core model: Intel Core i5-7500 bits: 64 type: MCP L2 cache: 6144 KiB
Speed: 801 MHz min/max: 800/3800 MHz Core speeds (MHz): 1: 800 2: 800 3: 800 4: 800
Graphics: Device-1: Intel HD Graphics 630 driver: i915 v: kernel
Display: x11 server: X.Org 1.20.4 driver: modesetting resolution: 1920x1080~60Hz
OpenGL: renderer: Mesa DRI Intel HD Graphics 630 (Kaby Lake GT2) v: 4.5 Mesa 19.0.8
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio driver: snd_hda_intel
Sound Server: ALSA v: k5.0.0-27-generic
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: 1c:1b:0d:e4:f6:10
Drives: Local Storage: total: 894.26 GiB used: 59.99 GiB (6.7%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB
ID-2: /dev/sdb vendor: Crucial model: CT480BX500SSD1 size: 447.13 GiB
Partition: ID-1: / size: 219.01 GiB used: 9.03 GiB (4.1%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 7.81 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 25.0 C mobo: N/A
Fan Speeds (RPM): N/A
Info: Processes: 177 Uptime: 10m Memory: 7.48 GiB used: 990.7 MiB (12.9%) Shell: bash inxi: 3.0.33
Are there any sensitive info there which will put my system at risk, like above command displays my MAC address.
since i have disabled the mouse pointer locater feature, system has not freezed.
If the it still freezes will let you all know.
Yeah that probably was the issue, I enabled it on Ubuntu Mate 18.04 which has mate version 1.20, and locate pointer option wasn't working and I used to get lots of crashes with msd-locate-pointer on the appport log. Tried a 19.10 daily build, which is using mate 1.22 and the locate pointer works fine without any hangs/crashes. So looks like it got fixed there.
