Ok I have a few questions here
Deja Dup tool shows ‘Backup Now’ button greyed out since I set it to the location and storage device and turned auto-backup on.
There is no status indicator to show the process or how far along it is.
Is there a way to check the status live?
Edit:
It finished after many hours and prompted in bottom right corner of screen displaying that backup is finished but it displayed this notification.
I have recently had a system update that mentioned conflicting .conf files, but I don’t remember which ones. The system updater asked me what I wanted to do about it and I selected to see the difference, then it never showed me the difference or I missed the message. After that I had to reboot, and then LightDM crashed. After the crash I selected to send report, but then a message displayed that I couldn’t send the report.
Is this a major problem that will effect a system restore? How do I fix this?
Also, how would I find any important conflicted configuration files?
