Can I do this on control-center, autostart? or…?
Create a quick bash (shell) script, since I believe the Startup Application command field only accepts one, otherwise you could separate them with &&
#!/bin/bash sleep 10 google-chrome-stable
Save the text to a file like delay_chrome.sh
- I think it's
(or for Chromium,chromium-browser
). - Change
sleep 10
to the number of seconds, or1m
for one minute.
Make the script executable (Right click file → Properties → Permissions tab → "Allow executing file as program" and then add it to your start-up applications.
thanks, works perfectly.
I have some difficulty starting ibus-hangul.
I have tried:
#!/bin/bash
sleep 10
google-chrome-stable && ibus-daemon -drx
doesn’t work, what is the proper wording to delay start 2 programs?
check in Control Centre > Personal > Startup Applications > Options and make sure there is no tick in the box!:
thanks, but on my PC, checking this does not seem to work to restart ibus
Use one &
symbol instead.
= Execute commands at the same time -
= Execute after the first one has finished.
thanks, lah7, works well.
