wolfman,
I followed the tutorial exactly, made a 20gb root partition, a 8gb swap partition, and the rest a home partition and the computer would not boot.
wolfman,
Ok, just settled on the default Ubuntu Mate settings, the system is running great now so just going to leave it alone. I know I should probably have a separate home partition but a lot of Arch users do it this way so I think it should be fine.
sda 8:0 0 238.5G 0 disk
├─sda1 8:1 0 512M 0 part /boot/efi
├─sda2 8:2 0 230.1G 0 part /
└─sda3 8:3 0 7.9G 0 part [SWAP]
I suspect it wouldn't boot because you didn't create a UEFI partition?.
It is up and running which is the main thing!. ![]()
Please tick best answer so it helps others!. ![]()
Done. Thanks wolfman
Hi @kreasonos,
when I get the time; I will amend my partition guide to include UEFI in glorious colour, I have never had to do it myself yet as I have only worked on two PC’s that have UEFI but it really just boils down to making a separate UEFI partition and then the normal swap, root and home partitions!. ![]()
I did work on one further laptop with UEFI but I used the auto install function as my friend was in a hurry!.
EDIT:
I have added UEFI info to the partition guide!. ![]()
