Display scaling resets after each restart
Hi
After installing mate 24.04 i have this weird problem, display scaling returns to 200, i tried changing scaling via mate tweak and terminal with xrandr but nothing works, i didnt have this problem with other ubuntu forks till now, is there any fix for it ? According to my searches its not fixable.
Update: Chatgpt solution, adding xprofile and set it to start on startup didnt work too
Hi, @Vergilangleos and welcome to the Ubuntu MATE Community!
Have a look at top panel menu System > Preferences > Hardware > Display and verify that Scaling auto detect is not selected.
Also pay your attention to Mate Tweak Windows HiDPI setting.
Thanks for your reply, i tested all configuration in tweaks and display but it resets anyway.
And chatgpt failed to fix it too,
This is all the steps i tried and failed so far
try this command in a terminal:
gsettings set org.mate.interface window-scaling-factor 1
and reboot
Keep in mind that the loginscreen also does set the scalingfactor.
( If something is wrong there, your scaling might be set inapproprietly)
Thom, I don't know enough to understand the contents of the following link, but ... could this be applicable or useful for the situation being discussed?
After 2 days i finally gave up, i dont know why this happens but it is what it is. Now i revert back to my old trusty mint.
That patch depends on being able to read '/etc/sysconfig/kernel'.
I don't even have that file on any of my rigs so I do think that patch is about something else :slight_smile:
