Does erase entire disc leave enough swap to suspend?
I am about to install and it looks like there is no swap with erase entire disc option.
Will laptop be able to suspend with no swap using erase entire disc option?
You should be ok with a swap file.
/swap partition : Since 18.04, a separate swap partition in most Desktops has been superseded by a swap file within the root partition. A separate swap partition is no longer recommended for most new Desktop users. Swap in a server is a little more complex; swap is recommended for some advanced uses (like non-ext filesystems).
However, if you really want a swap partition, you can use the something else... option
and create one.
Click on +, choose its size and mount as swap.
A swapfile is automatically created, this has been the case since Ubuntu 18.04.
