Does octoprint run on Mate 2204
This post was flagged by the community and is temporarily hidden.
            *  *  * FIX FOUND *  *  * FIX FOUND *  *  *
A solution that WORKS was suggest to me on the Octoprint forum. sudo systemctl disable brltty
Another FIX I had already used is found at: usbfs: interface 0 claimed by ch34x while 'brltty' sets config #1 · Issue #18 · juliagoda/CH341SER · GitHub
